It's looks hard to reach but if you lay down and stick your hand inside the fairing from the bottom you can reach all the way to both those two front/bottom fairing screws. If the one at the very front is stripped remove the one before it....helps to get your hand in better. Don't bother trying to take the chin guard/radiator guard off and go in that way...it's looks tempting but neither you hand or plyers fit. Just simply reach in from the back. I keep a spare stock of the Those rubber groments compress nuts as after a few uses they do tend to just spin. Sometimes too if you apply downward pressure to the allen head while turning it (like putting a platic item between the screw head and fairing, it may be enough to stop the groment from spinning and get the allen screw to come out.
