1 - 3 of 3 Posts
I have checked the headlight fairing part numbers from Ducati Omaha's website.
2004 ST3 481.1.031 1AA
2007 ST3s 481.1.031. BA
It appears from the 2004 diagram that the bottom fairing mount at the outer most lowest edges is moved back.
Has anyone interchanged from these years?
Thanks!
They are showing you is difference between 2003 (and older) and the 2004 fairings, not between 2004 and post 2004. I believe that “moved” may be a typo that should be “removed”, see the diagram for side fairing.
1 - 3 of 3 Posts
