1 - 7 of 7 Posts
Because my duc is leaking fuel on my pants after I fill it up I decided to add some more rubber to the filler cap seal so I took it apart. 2 screws later it easily came apart in pieces. Now I am faced with the de-lima in not knowing how of re-assemble it. My Haynes manual has no reference, so I am hoping someone has an idea where to find a pic showing me how to put humpty-dumpty back together again.
Done, thanks
if it is like the st cap the latch faces forward, the small spring goes behind the latch, to dive it closed when the cap is closed, then the cover with the 2 screws. the cap on my 98 st was leaking and i replaced the seal that is just below the key shaft. i had to dig the old seal out and replaced it with an oring. i did that in march, no more leak.
Parts manual? Do you know where I can download this? I was working on something earlier and an exploded view would've helped greatly.
1 - 7 of 7 Posts
