ciao a tutti -
one of my electrical engineering type geek friends just picked up the exhaust flapper valve assembly from my hypertard ... he is designing a dongle type plug-in for the 6 wire connector that hooks the flapper valve assembly to the wiring harness and ecu.
he believes he can build this dongle so that when you remove the flapper valve assembly (either disconnect it from the wiring harness, or remove the riser pipe with the assembly on it, and replace with a straight riser pipe) and plug in this dongle, the dash will not display any error codes due to the flapper valve not being there.
more on this project as it progresses.
ciao,
johnc
ciao,
johnc
