1 - 8 of 8 Posts
Lambda sensor & exhaust flap ?
Hello,
Do you know if the monsters (696,796,1100) have an exhaust valve/flap/servo inside?
I'm talking about the component that changes at low and high rpm.
Second, do you maybe know what is thread size of the stock lambda sensor ?
Thanks.
it's directly below the rear brake lever on the 1100 EVO - I have a small black cover between the point where the pipes join and the point where the silencer unit connects.
Beta Tester
the 2012 696 does not have a servo actuated exhaust "flapper" valve, and the 2012 1100 does.
i don't know about the 796 or the 795.
The 796 does. The servo is beneath the seat and the valve is on the exhaust before the Y connector beneath the rear subframe. I removed the servo motor and installed a Duc.EE.
Discussion Starter · #8 ·
I just looked at the sapre parts pdf files at ducati site.
The 696 doesn't have this flap but the 796 and 1100 does have.
1 - 8 of 8 Posts
