I have been experiencing excessive oil blowback on a new to me 998 that had 2mm overbore HC Pistal pistons installed, along with blueprinting.
The problem first reared its ugly head when I did a quick run up a local mountain. On the way home, oil started to burn on the exhaust which had originated from the rubber tube that drops down to the bottom of the engine from the oil breather. I took the bike in and they could not find any other source. They tried to assimilate the issue but could not and concluded that perhaps with the engine being relatively fresh, that the rings hadn't bedded in properly yet.
Yesterday I did another mountain run and the problem mainfested itself what one of my riding partners described as "a huge puff of white smoke" upon decompression going into tight corners. There was also a disturbing film of oil on the fairings (mostly the left side).
Help! Any similar experiences or suggestions?
