We got a very good price on the last batch of EVR products, so we are passing on the savings while the supply lasts.
EVR Ducati Progressive Engagement Clutch Pressure Plate
was: $220.00
Sale:$176.18 FREE Shipping
CNC machined progressive engagement vented clutch pressure plate for all Ducati dry clutch models (non-slipper type) made by EVR in Italy. The progressive engagement plate attached to the back of this pressure plate allows a smooth and progressive engagement of the clutch when your release the lever and start moving forward. The stock setup is very abrupt and causes a squeal, rattle and harsh vibration, which can be unsettling. This pressure plate resolves all that.
This pressure plate also features the patented EVR ventilation system, which lowers the operating temperature of your clutch 10% increasing the lifespan. Includes pre-installed SKF pressure plate throwout bearing (same as Ducati OEM) and CNC machined bearing cap which is a design feature totally unique to the EVR pressure plates.
EVR Ducati Vented Clutch Pressure Plate
was: $160.00
Sale:$131.22 FREE Shipping
CNC machined vented clutch pressure plate for all Ducati dry clutch models (non-slipper type) made by EVR in Italy. Specially designed ventilation system cools your clutch lowering the operating temperature 10% increasing the clutch lifespan. This pressure plate is also designed to protect your clutch in the event of a crash. The clutch hub posts are prone to break in crashes. EVR has made the plate height tall enough that the clutch posts, springs and retaining caps are protected - greatly reducing the chances of damage in a crash. Includes CNC machined bearing cap which is a design feature totally unique to the EVR pressure plates.
Available in your choice of 16 color combinations, more than offered by any other manufacturer. The bottom plate and top plate are each available in your choice of black, silver, gold or red. Colors below refer to the bottom plate color first then the top plate. The bearing cap color will match the top plate color.
*More EVR deals:
http://motowheels.com/b-32156-evr.html
* Outside continental USA, use shipping coupon codes:
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items OR upgrade to lifetime VIP passwords for the deepest discounts on ALL Items. Look for memberships and choose the membership type that fits you the best
