I can't disagree with that. They look nice. I’ve found EVR also sells just the normal plate that looks about the same for less money. There is a video floating around that shows this thing doesn’t really make much of a difference to the clanking. The quiet clutch mode does do the trick though, and as a bonus, your plates will actually need to be replaced because the friction material wears out and not because the thing has beat itself silly for 10 or 15K miles and you now not only need plates, but the basket is junk too!
I put in a new clutch (whole deal basket, plates, hub) @ 26K miles, along with the quite clutch mod. I’m pushing 40K and the clutch is a bit rough lately. You know the squeal and groan. Grabby too. I pulled it apart to clean it last weekend. The plates are getting pretty thin, but the tangs and basket still look great. First time in almost 90K miles on two Ducatis that I will put a set of new plates in the bike without also needing to replace the basket! A big plus to that mod.
