Hi everbody,
This is my first post so I hope I don't screw it up.
Anyways, I bought a 2016 Multistrada and removed the Evap Canister (charcoal box) a couple of days ago.
I found a lot of posts about how to remove the canister which helped a lot, but not much concerning that new electronic in line sensor thing on the left hand side of the bike.
I left the sensor connected in place, removed the hoses and plugged both sides of the sensor using vacuum hose plugs. This morning I was on my way to work, and got an error message. After work everything was back to normal and the light was back off as it should be.
Is the best bet to plug both sides of the sensor, leave it open on both sides, or remove it all together??
Any body know the answer or have and advice.
Thanks for the help.
