EOBD cut out on a 999
1111 0
Anyone out there had this problem. The EOBD and fault system kicks in as the bikes warming up or until you build the revs up over 5000rpm (though not all the time), you come off the power and the bike settles down again, only to come on as you start to ride hard. Its not temperature because its averaged about 98 degrees. Any ideas would be much appreciated. Mine is used on track tool (no road) only so if its not up to the job its gonna get the boot.
Thanks
