OK, now what? I'm getting tired of this.
The engine starts and runs fine until about 170 degrees then it acts like it's got a bad plug wire or something and stumbles at lower rpms. Reving it makes it almost go away with just a hit of a miss. I don't want to ride it like this because it can die at the lower rpms.
I just set the TPS again, making no difference. The spark plugs are new, which doesn't mean anything but I don't suspect them because the higher revs make it better, not worse.
I'm guess a temperature sender, does that makes sense (before I pull the fairing off (again).
