Engine Light on after head light bucket removed
910 4
Hey People!
Ok, so I finally removed my headlight bucket - which was a long time coming. As soon as I connected everything back together my engine check light lit up!
I did not connect the air temperature sensor back, simply because I was not able to remove it from the headlight bucket without excessive force. I really did not want to force it...
will reconnecting the air temperature sensor turn the check engine light off?
· Registered
Having the ATS not connected will definately trip a CEL. On startup, the ECU makes sure everything is functioning properly. If something is not working (or disconnected) it lets you know there is something wrong via the CEL.
· Registered
Thanks guys.
I will gently try to remove the air temperature sensor from the head light bucket. If it is too hard I will purchase an extra one from Ebay.
You guys are great
