So yeah... I have my the bike back together after having gone through most of the basics to get it track ready. Go to start it again for good measure and it just dies out on me. Thinking it was electrical (cause isn't it always!!??) I start looking through the loom and diagnosing the problem to no avail.
low and behold the BRAND NEW spark plugs are completely fouled and covered in oil. So me thinks the engine decided to forgo a day at the track in exchange for an exceptionally LONG string of four letter words...
I am assuming this means oils getting in via piston rings or some other gasket or seal is busted. This also means the engine needs to come apart and that is not going to happen prior to Friday afternoon. You have NO IDEA the level of disapointment here.
Thankfully I have long ago realized the best way to make a reliable ducati is to have two of them. The track body work, tank, rearsets, etc are going on the other one tomorrow and I'll have to refit the frame sliders as well. And what's worse is that I have newer tires on the track bike... (should be a no brainer to switch you say) but I ask how can I switch wheels from 2 bikes with one set of stands :-\
grrr just grrr
Now my questions for everyone is simple:
Any suggestions now that I'm taking the engine apart?
Any things to look for?
Any tips/ tricks?
Any goodies that I should look to add while the case is open?
Any body want a 748 engine with High compression pistons?!
Suggestions comments welcome.
grrr just grrr
Any tips/ tricks?
