Just in case 1260 owners are wondering if a damper can be installed on a 1260 here it is. I wasn’t crazy about the Ducabike one that mounts on the tank, so I did some research and with help from this forum (Thanks Tim) I managed to fit the Enduro 2016 damper on the 1260. No mods or special non oem brackets needed. Straight bolt on.
Next step, I’m debating to see if a damper from a sport model or street fighter will have a slightly stronger damping since most likely it will slide right in the clamp or see if a Hyperpro would fit since there is one with a similar mounting bracket.
Fist picture is oem enduro damper on 1260 and second pic is the Hyperpro damper.
