1 - 2 of 2 Posts
Can't get the battery light to behave itself and I'm not sure why. Flickering at idle is understandable, but there's a weird battery light dim then a bright flash on sharp acceleration and the indicator light is still on and flickering until voltage is above ~14volts which seems pretty high to me.
Yuasa Battery is a year old and holding a charge or 12.5V when the bike is off.
I'm wired up per the electrosport diagram (attached to this post).
Red wire direct to the battery +
Green wire direct to the battery -
Yellow wires to the generator of course.
White wire to the ducati white/bk wire that goes to the battery light.
Making 13.5V at 1000rpm, 14.3V at 2700, nice and steady at 14.5 above that, so the new R/R is doing its job I'd say. Voltage measured across the battery terminals.
This thread was helpful:
http://www.ducati.ms/forums/57-supersport/118536-new-voltage-reg-then-nada-2.html
Especially the blue diagram that MrSpigot attached, which is exactly how I have mine wired up right now.
Any thoughts to clean up this weird light behavior?
Discussion Starter #2
Situation improved but not solved by cleaning and up all of my ground connections and trying again, especially the ground wire connection to the R/R itself. Still get the flickering below 2k rpm and that bright indicator light flash when I snap the throttle open quickly.
1 - 2 of 2 Posts
