1 - 7 of 7 Posts
Mayor of Simpleton
Bike turns over with the key in the off position. Bad solenoid? Bad starter switch (doubtful)?
Mayor of Simpleton
Discussion Starter #2
Hmmm. Swapped (used spare) solenoid. Doesn't turn over with key off, but also doesn't turn over with the switch...
Maybe the original was shorted open and the used replacement is just bad?
Mayor of Simpleton
Think I got it. Checked the white plug and works now.
Thanks for all the help. :)
It seemed like you talked to yourself right through the problem. Nicely done nine. (the voices in my head dont answer back)
As I often tell people (including myself) sometimes just stating the problem provides the solution.
I'll file that away for my 916. Thanks.
1 - 7 of 7 Posts
