1 - 3 of 3 Posts
Is the 998 the same as 996? Wondering if its viable to swap and fix issues with fueling, i.e. dual injectors/single injectors. Thank you for insight.
Unfortunately not, the 998 uses the 5.6m ECU (located near the battery) which is physically different (plugs and shape) to the units on the 996 (located in the tail)
Even the 996 has two possible ECUs, the regular bikes use the 1.6 ECU whereas the SPS versions use the P8 ECU.
Andrew...
Andrew...
Thank you Andrew for the quick response.
1 - 3 of 3 Posts
