The bike has termis 2-1-2 how can I tell if this is slip on or full?
Also when I turn the ignition on it says HYM Racing. Does it mean that I have ECU? This is how it was on my full termi setup on 1098.
You can identify a full system simply by looking at the pipes leading up to the
mufflers. Full system removes the catalytic convertor (4" diameter can
behind the engine, look behind right footpeg) and also removes the exhaust
flapper valve (small bulge in exhaust just before entering the mufflers that
has two black cables coming out of the inner side, look below right side
of the seat).
"HYM Racing" at power on indicates a DP ECU has been installed. They are
included with any Termi system.
