I'm having my stock ECU remapped by Motowheels and so I'll be removing it from the bike this weekend. Is there anything that I should be aware of/becareful of before I remove it besides disconnecting the battery? This is for a 2006 ST3.
Also, I'm installing new pipes (hence the need to remap the ECU) and during the process of swapping out the stock pipes for the news ones, I plan to remove my exhaust headers and have them ceramic coated. Does anyone know of anything I should be aware of when doing this and also, what do others use to close up the hole/port where the lambda sensor was fitted since this sensor will no longer be needed when I install the new pipes?
Thanks!
Howdo!
Using an ST3 engine in my bike and had to fit lambda bungs to the headers when I got the bike remapped, these came with the end cap (Few on e-bay).
As long as you have disconnected the battery you should have no problems removing the ecu.
Are you putting the bike on a rolling road (See before/after)??
Good luck with the bike Pablo
Hey Pablo ...thanks for the feedback. I think those bungs you're referring to are only in the UK. I don't see them on the U.S. ebay site. But at least I know what to search for. Not sure what you mean by rolling road (before/after). Thanks again :)
Howdo!
On the Dyno (Before/After) :D
Is there another model in the Ducati range you can used the bungs from? The older SS has no lambda sensors but has the bungs fitted?
Cheers Pablo
