1 - 7 of 7 Posts
Hello. The ECU on the Monster400 IE 2004 broke.:mad:
There are two questions:
1) Someone has firmware (software) for the monster 400 IE (injector).
2) Will the ECU come from ducati 848? Will there be a firmware (software) installed on the ECU (Dukati 848) from Dukati Monster 400IE?
On my ecu the following information: IAW 5 AM.A0/HW103/1210-DU35
Can someone have an unnecessary ECU block?:surprise:
In which way did it break. Most of the times you can still get the map from the ECU even if it us broken.
What you need is a Replacement ECU of the same type. 15m, 59m or 5am. Dont know which one you have. It also need to be the same HW number.
If you have that you can flash your new ECU with you original map.
Sent from my SM-G935F using Tapatalk
Now i see in you message. You need a 5am HW103.
With that things can be sorted with the correct cables and software.
Hey. Thanks for the response and tips. I understood everything at the EKU number: 5AM.
But if I have 5AMHW610. I can not find 5AM HB 103. The firmware (software) will not install on it? Will the motorcycle work badly or will not it?
Is it necessary that the HW103 number match?
Yes you need a HW103. If you flash a 610 map in a 103 you will kill it.
Maybe it is possible to get a 610 map for the bike. I dont know. The problem is that 400 bikes are not very common.
Discussion Starter · #7 ·
Hello. If anyone is interested and someone will benefit from my experience.
I bought a 5AMHW610 unit (It differs from what I had: IAW 5 AM.A0 / HW103 / 1210-DU35). From another motorcycle, similar to mine, the firmware was downloaded and uploaded to this unit. After that, my motorcycle earned. The immobilizer works. Somehow, the information from the immobilizer block was transferred and programmed in the ECU unit independently. The block that I bought was taken off the ducati multistrada 1200.
1 - 7 of 7 Posts
