After multiple searches I'm having trouble figuring out which ECUs I can use to run a 2007 Multistrada 1100 engine. I know an ECU from a 2007 multi will work, as will a microtec, but beyond that I'm stumped. Could someone point me to a resource to educate myself on the various Marelli units, their configurations, and capabilities? I'm fine with getting cables and software and re flashing, as long as the ECU is capable of processing the signals and returning valid outputs to the injectors/ignition. For this project it just needs to run the engine,no traction control, abs or coffee maker. Thanks for the help!
