I had the same question and asked my service guy. The air filter is under the black plastic covers/air intakes just below the front of the gas tank. I think you can just remove a cover and slide it out.Can anyone tell me where is the location of the above and what needs to be removed? Just received my Termi slip on and dont want to play where is Waldo with the ECU and air filter.
Thank you in advance
The ECU is under the tank someplace, but I have no idea how to get the tank off. It clearly is a harder proposition than my old monster, which just had one latch to lift up.
BTW, where did you get your Termis?
