It says "about 3-5 hp and 5 lbs of torque." It also says "Will save you about 4 lbs of total weight" Then it says "Each Kit is Quality Checked at our shop with an actual R1 exhaust setup before it goes out to our customers!" So, not really a Duc specialist.
This just seems to me like a glorified muffler repack. They put the name race in front of it and tell you it increases air flow. They neglect to tell you that if you change your stock exhaust configuration, you really need to re-map your fuel system to balance it out. I'm leary. Do you need a new exhaust?
I bought those and made a set, but I ended up getting a set of Giannelli's because the Gianellis have silencer inserts that you can take in/out.
(when I work graveyards I put the silencers in. even though I used to own a HD and also built my own custom Low Glide, I am not of the "look at me" set nor do I ride around in the GYN position)
I am going to put them up for sale soon
