Orient Express is pleased to offer Eazi-Grip tank grips from the U.K. for most late model Ducati machines. Eazi-Grip is available in both clear and black versions, pre-cut to fit your specific machine, as well as in universal fit patterns and rectangular sheets.
Eazi-Grip tang grips are offered in Evo and Pro versions - which each offer different levels of grip (again, both are available in black or clear).
Eazi-Grip is a specialist U.K. manufacturer of high performance motorcycle tank grips. Eazi-Grip works in close association with leading teams in the BSB & WSB paddocks and has developed two unique tank grips (Evo + Pro) that have been designed specifically with one purpose in mind – to assist in better bike control.
The Eazi-Grip Pro tank grip features a unique, circular embossed pattern, with a sleek and more dynamic profile. The Eazi-Grip Pro series tank grips have been specifically designed to allow greater movement on the bike while giving high levels of grip when needed, under heavy braking conditions for instance.
The Eazi-Grip Evo tank grip was launched in 2011 and features unique hemispherical traction domes that offer high levels of grip, combined with exceptional rider feel. Working closely with feedback from leading BSB riders, the Evo tank grip has evolved to the stage where it is now the product of choice in the paddock.
EAZI-GRIP BENEFITS
EAZI GRIP TANK GRIPS
Eazi-Grip tank grips have been specifically designed to assist in better bike control, enabling a rider to maintain a stable body position during cornering and braking, while also relieving rider fatigue.
CUSTOM FIT TANK GRIPS
Eazi-Grip tank grip traction pads are supplied pre-cut to fit a wide variety of bikes. For more unusual applications we also supply universal sheets that can be cut to the required profile. Eazi-Grip tank grips are available in black and clear. Eazi-Grip tank grips are easy to install with very little prep work, and can be removed if desired as well.
HIGH QUALITY AND DURABLE
Eazi-Grip performance tank grips have a soft but durable surface. Eazi-Grip tank grips and are manufactured using polyurethane, a highly flexible synthetic material renowned for its strength and durability. In comparison with materials such as rubber and pvc, polyurethane has excellent anti -vibration properties, will permit heat dissipation, has a superb coefficient of friction, and being 100% UV resistant will not yellow or harden with age.
Eazi-grip EVO sample
Sample image to show shape of product. Your actual product may vary slightly. Sample image below to show close up of Eazi-Grip Evo surface.
Eazi Grip PRO sample
Sample image to show shape of product. Your actual product may vary slightly. Sample image below to show close up of Eazi-Grip Pro surface.
Click below to view the full range of Ducati Eazi-Grips we offer. Please call 800.645.6521 with any questions before ordering, or if you can't find what you are looking for!
Ducati Tank Grips Body Control Enhanced Body Position
