I know this subject has been covered before, but due to financial constraints, and wanting to buy locally, I am looking for your help.
Click on this link and check the component part numbers and tell me if I have got it right, are these the correct parts to order to do the dzus conversion on my ST2?
http://www.southco.com/product/part.aspx?pn=D3-316-419-170&pns=D3-336-300-190;D3-326-100-040
I know I can get them from LT at Desmo Times & others, but the exchange rate and postage is murder.
Thanks in advance,
Craig
Thanks in advance,
Craig
that's one part. you'll also need the plastic washer and the clip.
call the seller to make sure the pin is long enough for your application.
some pins are shorter
The other parts & numbers are shown below the main photo, are they the right ones, and I have read previously that 19mm long is required?
Craig
Thanks in advance,
Craig
What you need:
Dzus Description Dzus Part No. Quantity
Panex Fastener Ringhead 4mm short 314-413-190 20
Panex Fastener Ringhead 4mm long 314-419-190 7
Panex Fastener Ringhead 6mm short 316-415-190 3
Panex Fastener Ringhead 6mm long 316-419-190 3
Panex Retainer 324-100-040 40
Panex Retainer (washer) 326-100-040 25
Panex Receptacle – slip-on 334-300-190 19
Panex Receptacle 334-100-300 3
Panex Receptacle – slip-on 336-300-190 2
Panex Receptacle 336-100-300 2
you will need a few rivited brackets for certian areas , stick with all the same length pins and get extra plastic washers to take up the extra space for panels that don't need longer pins.
more than likely 19mm all around with extra washers .
post pics when you get it sorted .
