I have a 999s and I want to put some different type of wheels on my bike I like the carbon wheels but dont know any thing about them as far as road use if they can take it
I wouldn't recommend race spec carbon wheels for a road bike. They don't provide good enough impact absorbtion to handle ordinary road conditions and run the risk of cracking. Why you try looking at a set of aftermarket Marchesini road rims? They have some nice forged aluminium ones.
BUT, and Martin will correct me if I'm wrong, I'm sure -- absolutely always make sure your tires are properly inflated. I don't have any personal experience with carbon rims, but I got a rear flat once and while trying to get safely to the side of the road I ran over one of those Botts dots on the freeway -- and it bent my OEM aluminum rim.
That was reparable (thank you Frame Man!), but I shudder to think about spending $2000 (+/-) on a BST rim getting a tire puncture and then hitting someting innocuous like a highway dot and doing irreparable damage to the rim.
On the other hand, my SS had a carbon-fiber race gas tank for many years. I crashed it, and the front end hit hard enough to bend the fork. That impact drove the clip-on into the gas tank hard enough to cause the left control block to explode into lots of lovely little plastic bits -- and the tank didn't have so much as a scratch. So that carbon fiber stuff is plenty strong.
BST wheels, beautiful, light, amazingly strong and the perfect addition if cost is no object. Mine are only a week old but the more I ride with them the more I love them. Combined with a good 520 kit they will make a noticable difference in acceleration, deceleration, and handling.
Exploding CF, thats funny , the only way these would explode is if you put some C4 on them......As long as they are being used in the maner that they were designed for there should be no worries. Road version for the road, track version for the track. Seems fairly straight forward to me. It is just a cost issue, you got to pay to play
You obviously haven't witnessed composite parts tested to destruction!
Each fiber can carry a lot of load, but when it reaches its limit, the failure is catastrophic.
If your wheels are designed with an enormous factor of safety, you'll probably be OK, but be forewarned; if you encounter a misplaced pothole or debris on the road and hit it at speed, the safety margin may not include such events. Then you will discover firsthand just how exciting a structural failure with carbon fiber can be...
Stick to forged Al or Mg. Maybe someday soon someone in the wheel business will "discover" Aluminum-Lithium and you'll get the best of both worlds, low weight and high stiffness.
I will take my chances with the BST's over any Magnesium wheel on this planet. Mg may be light but it has an extremely low modulus of elasticity as well as a very poor fatigue resistance, OK for the track but crazy poor for road use.
It does make for a good read. And as always it simply proves the fact that opinions are indeed like *%#holes, everybody has one! And are entitled to them
Cheers
I will keep happily rolling along on my BST's, at least until they explode and create a massive intergalactic dis-continuim....then its off to the restaraunt at the end of the universe for me.
Well, the more I work with composites- the more I like composites. You can design and make composites as strong or as light as you want if you have the proper experience and resources.
BST test 5X stronger than aluminum. By the time the BST wheel fails from impact, the bike itself experiences catastrophic damage. Every broken BST wheel that I have seen was attached to a damaged bike that had experienced very serious impact.
The new BST motocross wheel which is good for 60 foot + jumps has a flex coating on the finish to handle the flex. Yet when ridden, the rider report less flex and prefer the precise feel of the BST wheel. The wheel is designed to be stiffer than laced wheels but it will flex upon had impact.
I was not surprised when I saw this test. We routinely drop the BST wheels on the pavement (without a tire) when people ask how strong it is.
Speaking from personel experience, We sell replacement aluminum and magnesium wheels at a much higher rate to percentage sold than BST carbon wheels. I have many more damaged magnesium wheels from incidents that the rider would have expected the mag wheel to survive. With the BST wheels, I've had the oppisite experience--There are many more stories where the customer expected the wheel to damage (ie: T-boning a mini-van, running into curbs, ladders and huge pot holes) but the BST wheel survived intact.
+1 to the above statements. BST has been in this game for a very long time. They have seen problems and corrected their designs accordingly. I have absolutely no worries riding and racing on their products.
OK. I've just seen too many dramatic failures. I could be persuaded though.
As I mentioned earlier, depending on the design margin, one could make a pretty safe wheel.
The strength's not the issue, it's the catastrophic failure mode that's got me spooked.
Yes I do believe that one can produce lighter structures with CF than with metal, but they are difficult to impossible to repair when damaged. And when they are repaired, don't retain the original strength. One of the reasons I love the Ducatis is the CrMo trellis frames - lighter, stronger, and more damage tolerant than their Al competition.
I have a set of BST road version for my 749R I picked up last year from Motowheels.
As with anything else that is divided on opinion, you will need to do your own research and come up with your own conclusions. I read all the message boards and all the threads and consulted with Nichols about the exploding BST that caused a stir a while back. In the end, with the un-official blessing of Nichols, I decided it would be ok for my particular riding style/application.
The rims are truely a beautiful piece of art work and makes steering much easier (sometimes too easy - which can be a bad thing as well). I make an effort to always check tire pressure before going out for a ride and carefully inspect the rims upon the bike's weekly cleanings.
I've still kept the original 10 spoke forged aluminum wheels as a backup precaution in case the BST gets damaged or if I start losing confidence in it one day. Once the bike is back in the garage, up it goes onto a front and rear paddock stand. These little things I do give me greater peace of mind.
I've also kept in the back of my head a budget to fully replace these BST Carbon rims in about 10 years with another set as a safety precaution and as an upgrade down the road (should I keep the bike that long). The rims would make for a nice piece of hanging art in the garage after that time.
Attached is a picture of the bike with rims on it.
seeing that no one knows why Sam's wheels failed....I think all BST owners should be congnizant of the need to very meticulously inspect the wheels during or after wheel mounting.
As for the bikes being destroyed......I just saw a new thread on speedzilla, about BST's failing during an accident where there was minimal damage to the bike itself.
funny how those who work with composites are leery of wheels being a correct application for CF.
at least with metal wheels, there's some visible damage that is a precursor to fatigue-related wheel failure.
Yay, another cf wheel thread! It has been a few months.
Anyway, seeing how this thread is titled 'Dymag Carbon Wheels' I've included a photo of ducati.ms member VIVID1 on my 996 when she came up and did a little ride a couple weeks ago.
My Dymags have about 15,000mi of potholes and frost heaves runnin thru the wilds of Alaska.
That is the SWEETEST Ducati that I’ve ever had the pleasure of riding, looks great, handles great, sounds awesome... when I got back to Chicago, the following weekend I found myself at the Ducati dealer sitting on a 999… am I in trouble now, maybe it's time to ditch the 954RR.
this argument never made any sense to me. if you "hit a misplaced pothole or debris on the road and hit it at speed", al, mg, or STEEL isn't going to make a difference. you're probably going down and replacing the entire bike if you survive. i don't think the argument of how a flattened and/or bent metal wheel is theoretically better than a shattered cf one will matter much.
I've got BSTs on my SS, and Marchesini forged magnesiums on my ST2. Weight difference is minimal (300g each, front and rear), but the BSTs feel much more lighter, probably due to most of their weight being at the hub. Never have had a problem with magnesium wheels, and the EPMs on my LeMans are 24 years old.
Tom
