Have you ever measured the front forks sag? I mean this:
With just the bike's weight and zero preload that distance is 100 mm (which means 70 mm free sag). With maximum preload it goes up up 115 mm (so the free sag is 55 mm). And this is with just the bike. There you have to add the driver's weight also.
I think the front is very soft if the general rule is that the sag should be about 1/3 of the front travel (170 mm) with the driver. Could you please measure your bike as a comparison to find out if there is something wrong in my Multi or is it the same with all the Multistradas.
