1 - 9 of 9 Posts
The Akrapovic Systems will always give you Optimal performance enhancement for your motorcycle. Unlike other alternative brands, our systems are designed and developed with all stock settings in place. This means that when you simply install the Multistrada system, you will already experience performance enhancement without additional mapping or modifications to the ECU. If you choose to remap later, you can always get even more out of an Akrapovic system.
Keep in mind there is also a full TI header kit for the Multistrada this year!
When will the Akra Revolution exhaust be available for the Multistrada DVT in the USA? Revzilla still lists it as 'out of stock.'
When opting for full Akra (Complete system with Headers+Slipon ) What do we do with ExhaustValve & O2 sensors ? .Hope you have left some instructions in box ?
Do you also have Remap Software for ECU update option , like Termignoni ?
Hello,
Revzilla should allow you to place a pre order if you give them a call. They have already shipped from our factory and should be arriving to the Revzilla warehouse within a week or so.
Mapping and Installation
Check out the below link to the installation manual online for this system, this should answer all of your questions in regards to installation:
https://d2wb124y84b8aj.cloudfront.net/akrapovicbppmultimedia/a4e49f8ea13542cbb0ec37c9f9753743.pdf
As for Mapping - Unlike Termi, when you install our systems you do NOT loose power. Our systems are designed and developed with all stock settings in place. When you install this system, you will experience the performance gains listed on our website. However, this is just a starting point. If you do choose to remap, you can get even MORE out of the system. Always remember that Akrapovic exhaust systems gives you optimal performance enhancement for your motorcycle from the start. For perfect performance and desired throttle response with your personal preferences you can always remap.
Our online performance stats are based on taking a stock motorcycle, running the dyno 3 times and taking an average of those out puts. That is then our starting point. We then install our system, make no other adjustments, and run the test 3 more times. Then we average those out puts and compare then with the stock results. Basically we are giving you a very reliable performance stat.
I think what the original poster (and myself) were hoping was that, since you are aligned closer with Ducati these days, you could provide a original OEM ECU chip upgrade for a complete system replacement as does Termi (at least in the case of my M1200 Monster).
As you say, to get the best performance out of a full system (NOT a slip-on), a remap is essential. The additional hardware (Bazzaz, Power Commander, etc.) to do this is an additional cost that cuts a big chunk of the price advantage you have over Termi, not to mention the extra work to install and debug the electronics and/or warranty issues with a third-party reflashing the OEM ECU.
Discussion Starter #8
You make a valid point. We specialize in being an exhaust engineering company and not a fuel management company. Although 98% of our systems, full systems included, are designed and developed with stock settings, we usually recommend reaching out to our partners at Dyno Jet for additional mapping advice. It is not in our plan to offer up-maps, or tuning advice at this time.
Discussion Starter #9
Shipping - Availability Update
Availability Update - The New Mufflers are set to ship out at the end of the month. Check with your local dealer to place a pre order. Header kits are coming in regularly but, continue to sell out. The smaller muffler style is still is currently in stock with both distribution partners.
1 - 9 of 9 Posts
