Here's a question for guys with the above wheels - how are they holding up to long term use? does the paint begin to flake off after a few trips in the rain, or do the spokes go rusty? How well do they cope with British type winters?
Thank you!
Alu Alpinas on my GT for 2.5 years ~20,000 miles
Spokes on front wheel have some pitting, rear wheel not as bad.
Stainless spokes not available afaik
Slight leaking from the Spoke Nipple O rings began fairly early and has gradually increased.
I recently tested the front wheel submerged in a tub of water and 12 spokes had slight leaks which amounted to around 2-3psi loss per day.
The roads in my region can be a bit rough at times so perhaps that adds to the stress on the Orings ? However even on perfect roads I think some spoke Orings will eventually leak over time.
The anodized coating on the rims and hubs is holding up ok, but requires care when washing as its recommended not to use any harsh detergents. Its a mat finish so chain lube or brake dust etc smudges rather than wipes off, so needs to be washed off. I believe the carbon matrix rims are a gloss finish which would be easier to clean.
Check with your Alpina dealer in the UK and ask what the policy is if the wheels ever need refurbishment. Maybe Alpina will cover it ?
