I will be installing a Ducshop linear link and Ohlins TTX on my 848 Evo in the next weeks. As I understand it, I will also need to get a ride height adjuster like the one from Sato and shorten it by cutting the rod. The stock tie rod on an 848 is 175mm eye to eye. The Sato one at its shortest length is 155mm eye to eye. Assuming I want to keep my current ride height what should the Sato adjuster be set at? Basically, I am trying to figure what the minimum length the Sato adjuster eye to eye needs to be to be equivalent to the stock tie rod after I install the Ducshop link.
