1 - 7 of 7 Posts
Hello,
This problem recently arose on my SF 1098 a few days ago.
The motorbike started having problems dropping in RPMs when letting off the throttle going to a stop (I’ve made sure the throttle cable was good). During decelerating the RPMs will drop down however there’s this clicking noise that happens for like 1-2 seconds then the rpms drop down back to idle.
Can anyone give me some insight please. Thank you !
Bon Vivant
Its been about 10 years since I've pulled my SF apart but if I recall the cables go to a TPS and the throttle bodies are electronically controlled by the ECU, perhaps there is a mechanical or software fault in the system there. I'd recommend you take it to a dealer.
The throttle body and butterflies are controlled directly by a cable. No ride by wire junk on the first SFS. I would check for a vacuum leak.
Flynbulldog, you always have good information to share. When you have a huge bank of knowledge it's impossible to remember everything. I know I sure can't remember everything.
There's a small stepper motor on the throttle body assembly for the idle control valve. This part being faulty could explain your erratic idle behavior.
The stepper motor has vacuum hoses that could possibly be bad/off.
1 - 7 of 7 Posts
