21 - 23 of 23 Posts
Svensk? Jag va född I Göteborg :)
Either way I'll continue in English to make things easier for everyone.
Have you gotten the engine to turn over by a push start? With the starter in the bike did you attempt to short the solenoid?
I'd be happy to help little by little with the knowledge I built up over the last month and a half!
Yes very much "svensk" still in Sweden.
The starter did turn but in the wrong direction :-( But I think I got info now how to solve it.
It´s always a problem when someone else has been tinkering with the stuff.
Are you saying the starter runs backwards?
If so the only way would be if brushes have been connected backwards. Possibly po put rear starter plate back 180 degrees out.
Thanks I+ll take it apart tonight att turn the plate.
Correction, I´ll sit on a my workbench with a beer and watch my daughter work :)
Problem solved, took it apart, turned some of the parts around randomly and now it work :)
Still having an issue with the starter relay, but that might be a new story.
21 - 23 of 23 Posts
