um, not sure if that helps lol. I only ask because after looking at YellowDucking's thread, he had to do some mods to his. I'm just wondering if all I have to do is install the quick change carrier and use the stock hub. I saw that he had his wheel lock up after the mod. I'm hoping to not run into that problem.Pictures will speak for themselves...
+1...get a dial indicator or one of those fancy laser thingies.be sure you check the alignment of the sprockets.
I just bought the whole kit, from Motor Sports Machine on EBAY. They had a 100% feedback. It was the front and rear sprocket with a billet quick change carrier. Specifically for the 748. Thanks for the helps fellas.I believe the sprocket he changed to was just standard aluminum, his pitch was also 520 which altogether lead to a failure-broken teeth. That was on his R1.
I like the 525 more than the 520. The 520 just doesn't last as long it seems. If I were to run a 520, I'd be sure to get a case saver and assure that the aluminum sprocket is at least a hard tensile aluminum (6061). I don't believe there is really any modifying that needs to be done so long as the carrier you get is specific to your machine.
edit- I guess his kit did not come with a spacer for the 996 model. Sorry.
http://www.ducati.ms/forums/showthread.php?p=539764&highlight=carrier#post539764
Chances are that was due to an issue of two hub designs.edit- I guess his kit did not come with a spacer for the 996 model.
