1 - 14 of 14 Posts
So I bought a 2007 1098 and the previous owner gave me a bunch of miscellaneous parts with it. It included some kind of programmer I am not familiar with. Does anyone know what I can do with this?
2016 blinged out PP
2007 Monster S4RS
Retired Pipe Polisher C2H6O+
That the VDSTS setup. About the only real function it has is to reset the TPS value in the ECU and run some diagnostics.
But be careful with it. It also has a nasty reputation for blowing a ground in the ECU if not connected properly.
Thank you! Can I reset the service indication after I do s valve check with it?
2016 blinged out PP
2007 Monster S4RS
And does it work on other models?
2016 blinged out PP
2007 Monster S4RS
Bon Vivant
Here are some bikes that share the 5AM ECU But this tool will work with other ECU's as well Techno research will tell you that its not compatible because they want to sell you more software but there is a list (that I havent been able to find yet) I know I used mine with both my SF and my MV agusta 1078
Monster 695 Magneti Marelli IAW 5AM
Monster S2R Magneti Marelli IAW 5AM
Monster S2R 800 Magneti Marelli IAW 5AM
Monster S2R 1000 Magneti Marelli IAW 5AM
Monster S4R Testastretta Magneti Marelli IAW 5AM
Monster S4R S Testastretta Magneti Marelli IAW 5AM
Multistrada 1100 Magneti Marelli IAW 5AM
Multistrada 1100 S Magneti Marelli IAW 5AM
Hypermotard 1100 Magneti Marelli IAW 5AM
Hypermotard 1100 S Magneti Marelli IAW 5AM
Superbike 848 Magneti Marelli IAW 5AM
Superbike 1098 Magneti Marelli IAW 5AM
Superbike 1098 S Magneti Marelli IAW 5AM
Superbike 1098 S Tricolore Magneti Marelli IAW 5AM
Superbike 1098 R Magneti Marelli IAW 5AM
Superbike 1098 R Bayliss LE Magneti Marelli IAW 5AM
Superbike 1198 Magneti Marelli IAW 5AM
Superbike 1198 S Magneti Marelli IAW 5AM
Superbike 1198 R Magneti Marelli IAW 5AM
Superbike 1198 SP Magneti Marelli IAW 5AM
Sport 1000 monoposto Magneti Marelli IAW 5AM
Sport 1000 biposto Magneti Marelli IAW 5AM
Sport 1000 S Magneti Marelli IAW 5AM
Sport 1000 Touring Magneti Marelli IAW 5AM
Sport Classic Magneti Marelli IAW 5AM
Streetfighter Magneti Marelli IAW 5AM
Streetfighter S Magneti Marelli IAW 5AM
ST3 Magneti Marelli IAW 5AM
ST3 S ABS Magneti Marelli IAW 5AM
I think so.
Also if you have an ECU that eliminates the O2 sensor you can use it to adjust the fuel trim. I almost forgot about that.
Just make sure you don't reverse the polarity of the battery connection! Ask me how I know? :)
Super Moderator
You might also consider whether your motorcycle consumption is becoming problematic or if you could quit anytime, you just don't want to.:)
That's a beautiful addition to the stable.
I can't comment on the programmer but it looks like you got a very complete bike. The books, manuals, all keys, and both the electronic and mechanical codes. That's pretty great. Congratulations, again.
Discussion Starter #13
Oh just because you're a shrink you think you know me?? I'm not addicted, I CAN quit anytime I want...(said with shaky hands covering tracks on my arm)
THIS time I'm keeping her, THIS time the magic will last, THIS time is different... I think...
2016 blinged out PP
2007 Monster S4RS
Discussion Starter #14 (Edited)
Thanks Sherpa!
I'm not sure why it came with 2 uncut red keys though, that's a first for me.
2016 blinged out PP
2007 Monster S4RS
1 - 14 of 14 Posts
