1 - 6 of 6 Posts
Hi guys.
Have 15 multi which is losing power while sharp/ tight cornering.
Anyone with any ideas?
Super Moderator
Welcome to the forum blodge!
You will have better luck posting your question in the Multi section or the Tech section of this forum. There will be more people looking in those places who can help you.
If it's abruptly loosing power, maybe a loose electrical connector that under strain in a tight corner.
I'm having the same issue. Engine bogs down while getting on the power coming out of corners.
Does your orange warning lights come on at the TOP of the dash when it happens?
Depending on how you have your electronics set up, you might be getting Traction Control activity mid-corner... if it's that then the power change should be smooth and controlled. If you're getting a sharp drop then it's something else and you might want to have your dealer look at the bike.
1 - 6 of 6 Posts
