Mr Leakered
This post is a closed post to be used as an ST specific library of threads and posts that are found most useful by the users of this forum.
To nominate an addition or revision to the this post, create a thread or post with a link to the addition or explain the revision. If other forum members find the addition or revision useful, then a moderator will make the change to the this post.
If posting a problem and a resolution, please include a link to both the problem post and the post that gives the fix.
ST Model Info:
http://www.ducati.ms/forums/40-sport-touring/15290-newbies-please-read-ducati-sport-touring-models.html
Bill_Anderson
Equivalent Parts Thread:
http://www.ducati.ms/forums/40-sport-touring/118762-equivalent-parts-st-bikes.html
Everyone
Service / Workshop Manual Thread:
http://www.ducati.ms/forums/40-sport-touring/136183-service-workshop-manuals.html
tonered
Old ST FAQ:
https://dl.dropboxusercontent.com/u/71253082/Ducati ST - FAQ.pdf
tonered
Sections:
Batteries / Electrical:
Air Horns:
http://www.ducati.ms/forums/40-sport-touring/630642-air-horn-not.html
Everyone
Current Check - Parasitic Drain:
http://www.ducati.ms/forums/40-sport-touring/636362-weird-idea-st-how-sticky.html#post6179818
Stick
Battery Cable Upgrade:
http://www.ducati.ms/forums/80-hall-wisdom/627546-low-buck-battery-cable-upgrade.html
Lanesmatb
The Two Headlight Mod: http://www.ducati.ms/forums/80-hall-wisdom/8463-both-headlight-mod.html
Bearings:
Brakes:
Chain and Sprockets:
Clutch:
Fuel and Air:
Fuel Lines in Tank:
Need a good post here!
Exhaust:
GPS / Accessory Mounts:
Handlebars and Controls:
Headlight - DD and others:
Maintenance:
Mirrors:
Mirror Springs:
http://www.ducati.ms/forums/40-sport-touring/621506-mirror-springs-help.html#post6058482
Yorik
Panniers / Cases:
http://www.ducati.ms/forums/80-hall-wisdom/12630-st_-rear-directional-relocation.html
Seats:
Suspension:
Adjustable Ride Height Rod:
http://www.ducati.ms/forums/40-sport-touring/498745-ride-height-adjustment-rod-st2.html#post5829521
Tires:
Tools:
Windscreens / Fairings:
