Hey guys. I have a Brembo p32 caliper and corresponding master cylinder. I do not have the lines that connect the two or connect the reservoir to the cylinder pump.
Where can I purchase this?
I only need the lines. I have the rotors, pads, caliper, banjo bolts, rear master cylinder and reservoir.
I need the lines for the caliper to master pump, then from the pump to the reservoir
Your help is appreciated !
I put this brake system on my cb750
