21 - 31 of 31 Posts
Discussion Starter #21
That's also in my to-do list! Learning to adjust the suspension!
There are a few good threads in here about. I am reading one where Shazaam gave an in-depth, but still accessible, run down of the settings and what they affect. Just building courage to put it in practice 馃槀
Smut peddler
Go to YouTube, search for Dave Moss suspension settings. Guy is awesome to learn from. Also, many shops will invite suspension techs to do informal seminars. The knowledge you gain from these will be more valuable than any bolt on upgrade. We'll, minus exhaust. That's just cool. :ROFLMAO:
Discussion Starter #24
Thank you for that. I have looked up his videos and you are right, he is the guy to go to. Now just need to get the tools 馃槑 (y)
Discussion Starter #25
So, I dove into the suspension and it is coming along together. Where do I adjust compression on the Showa forks? I am assuming above the pre-load hex nut, but which side? Is it left rebound and right compression? I鈥檝e checked the manual and it has a different fork in the picture altogether (Marzocchi, If I had to guess).
Retired Pipe Polisher C2H6O+
Compression is up through a hole in the bottom.
Discussion Starter #27
Thank you, I鈥檝e been looking everywhere for it. All the tutorials explain what each setting does, but not where to adjust them. I鈥檒l look for it when I get home today.
Discussion Starter #28
Just found it on a diagram for the S4. I couldn鈥檛 see it before because my axle isn鈥檛 lined up with it. Thank you for your help.
Discussion Starter #29
Now I only have to con a friend into actually helping me in setting proper sag 馃槑馃憣
These forks usually have a lot of stiction. To help get a fairly reliable measurement go out and ride the bike for a while to warm the suspension up. Then back off all damping adjusters to full soft to let the suspension move more freely. Do your measurements and set accordingly. Then reset the dampers. It helps.
Discussion Starter #31
Appreciate the tip. I had noticed some stiction when I was playing around with preload and checking travel with a zip tie. That should make things a lot easier. Thank you 馃憤
21 - 31 of 31 Posts
