BillG .... good advice but the 600 and 7500 mile service does NOT cover the Streetfighter...
I am referring to the recently announced maintenance program. Here is what is on Ducati USA web site:
What models are eligible for the program?
All new 2008 and 2009 Ducati models purchased from June 4, 2009 to August 31, 2009 at participating dealerships.
How do I know I am signed up for the program?
Your dealer will have you sign an acknowledgment form and then register you online. An e-mail confirmation will be provided to you once the paperwork has been received by Ducati North America.
What services are covered under the program?
The Full Factory Support maintenance program covers the first two services as outlined in your owners manual and include:
Service 1: to be performed within 6 months of delivery date or 600 miles, whichever comes first.
Service 2: to be performed within 12 months of delivery date or 7,500 miles*, whichever comes first. To be eligible for the program, Service 2 service must be completed no later than 30 days within one year of the delivery date of your motorcycle.
*If you reach 7,500 miles within the first year you are also eligible for Service A (valve inspection) to be done in conjunction with the 2nd Service. See your owners manual for complete details.
What items are included in the services?
Service 1 includes the following maintenance operations:
* Change engine oil
* Change engine oil filter
* Check brake and clutch oil level
* Check chain tension, alignment and lubrication
* Check brake pads. Replace as needed
* Road test motorcycle
Service 2 includes the following maintenance operations:
* Change engine oil
* Brake and clutch controls check and adjustment
* Check and lubricate starter/accelerator controls
* Tire pressure and wear check
* Check warning and instrument lighting
* Check and tighten engine to frame mounting nuts
* Check side stand
* Check front wheel tightening nut
* Check rear wheel tightening nut
* Check external fuel line
* Check front fork oil and rear shock absorber for leaks
* Check front sprocket
* Lubrication and greasing at all required points
* Check battery and charging system
* General cleaning
* Check coolant level (4 valve models only)
* Check power fans and cooling circuit seals (4 valve models only)
* Change fuel filter (S4RS and S4R models only)
Ducati service intervals and required operations are related to both time and mileage. Note that if you reach 7,500 miles within the first year you are also eligible for Service A (valve inspection) to be done in conjunction with the 2nd Service. See your owners manual for complete details.
