Hey all-
I just made my 1st upgrade to the Hyper. I'm pretty tall (6'4") and have size 14 feet (48 euro), so a little extra leg room and room to fit my boot between the stock peg and shifter was necessary. My foot actually got STUCK during my 1st ride, and I came close to crashing while trying to un-stick it!
I had been considering the Ducati Designs adjustable pegs for my MTS 620, but never got around to ordering them. The day my foot got stuck is the day I ordered the DD pegs for the Hyper!
I ordered the silver "race" style pegs with 30mm adjustable arm on Thursday, and they arrived on Monday. Pretty darn quick, especially since DD ships from California, and I'm in NY!
The pegs and arms are billet, and they are beautiful! You can see the attention to detail and design. Very nice. They are light, yet feel totally solid. No junk here. And they look awesome on the Hyper! Like they were made for it. (They are!)
There are 8 possible settings, achieved by rotating the arm around a stepped ring that mates with the peg mounting hinge. This is a well thought out design. The connection is solid yet easy to change with an allen key. Loosen the arm and rotate to the desired position, then loosen the peg and rotate it to taste. Takes all of 15 seconds.
This mod has transformed the Hyper's leg and foot room for me, and makes shifting a pleasure. No more stuck boot! The pegs are very comfortable, wide, and just grippy enough to feel secure.
Highly recommended.
Note that, to install the right peg, you need to loosen (not remove) the two gigantic allen bolts at the bottom of the peg bracket, as well as the huge (24mm) nut on the side of the bracket. Slightly twist the peg bracket to allow clearance so you can remove the peg mounting pin, which otherwise hits the engine casing.
Highly recommended.
