1 - 8 of 8 Posts
Retired Pipe Polisher C2H6O+
OMG! It’s like Gone With The Wind for chains. :)
"Statistically, it has been found that the average service life of a final drive chain is about 20,000 km, only if it is periodically maintained in accordance with the instructions given in the Owner's Manual of the motorcycle."
20,000 km is around 12,500 miles. Hmmm.
1994 Ducati ss/cr
Additional chain precaution trivia
Something to add to the general subject of drive chains, briefly alluded to in that excellent
Ducati bulletin....
Somewhat obvious, but I have worked on bikes that had this wrong.
Battery acid is immediately fatal to a drive chain.
Battery vent tube outlet should be routed to the opposite side of the bike.
A dramatic demonstration is to hang an old used up chain, and brush some acid on it.
You'll hear a crackling sound as the links fracture and often the result is chain pieces
in a pile on the floor.
I discovered this as a kid when I put Naval Jelly rust remover on my bicycle chain.
Wow. I knew enough to purchase a replacement chain but that REALLY went into detail. Thanks for posting!
1 - 8 of 8 Posts
