Hello
I was looking at a used 999 exhaust at a wreckers which is listed as a 04-06 999 exhaust can, however, it says on the can ONLY FOR RACE USE . Then 573.1.081 below that
There also is a ZS pattern in the metal on the top side near where the mid pipes connect. Attached some photos below
It's just the can, no pipes. My plan is to put it on a base 749
I can't see Termignoni written on the can anywhere...is this just the stock OEM can that would be equivalent to what I have now, or was this a different version.
Really just looking for more sound and this would be a good deal if not the same as stock
Appreciate any input
Thanks, if its from an R model will it be louder, or have a nicer sound?
Is there any mapping concerns or should it fit right up without remapping?
From a bit more research it would seem this was the optional race kit for the early 999R's.
Can this be run with the stock mid-pipes, or would it be necessary to also get a cat less mid-pipe as well.
I believe the cat is now removed from this muffler, which would leave only the cat in the long mid pipe. is that doable, or will it cause issues with only one cylinder having a cat?
Thanks again
