1 - 6 of 6 Posts
hello all,
Was wondering if there is a solution to the tank filler cap reservoir drain hose being clogged not draining after rain water accumulation.
Cheers
the 999 one possibly has quite a sharp bend just down the pipe, and that can be a real issue to unclog. might need to spray it down with wd40, etc, for a while and eventually it might soften the rust and blow out. blowing through them is an item on my service tick sheets these days - i see lots of blocked ones. those screw in aluminium inserts in the plastic tanks are really bad for it. i use a 2.5mm drill bit on them, no other way to do it.
1 - 6 of 6 Posts
