1 - 3 of 3 Posts
Ok I have a strange issue where my high beam (Right hand side as you sit on the bike) doesn't work on my 2002 998. The regular beam does which rules out the fuse as it's shared. I do have a Euro style swith which allows you to turn off the headlights. Also I should add that the high beam blue light on the dash doesn't illuminate either. I'm guessing it's not a bulb issue but probably the switch? Any other thoughts. Every thing else works fine on the switch including the signals. Anything else I should look for?
If you look under the instrument cluster mounted on the headlamp bucket you
should see two relays ? one for the dip beam, one for the main beam.
could be the relay for the main beam has given up.
brian.
brian.
Good thought Brian I will check that out cheers.
1 - 3 of 3 Posts
