OK my bike was missing the front blinkers when i got it. I am trying to locate the wires to install new ones. Where would the wires be located at? Any help would be appriciated. Thanks
White/Black and Black wire for LH front and White/Green and Black wire for RH front signal. They come from the underside of the headlite housing....or...they may be inside your air intake runners. Once you remove the headlite fairing you should see them. Mine is a 2001, but it should't be much different.
If you want them, I understand. But you don't need them to pass inspection if that's why you want them back on.
