Hey all,
After my SP3 got stolen, I am so paranoid about losing my SPS. I have bumped up the security at home and obviously have insurance but the issue is really that if I lost the bike, I couldn't replace it. I have been pondering fitting a GPS tracker but am not sure how effective they are (need line of sight with the sky, own power supply etc.) and also whether I could fit one to the bike in a discreet enough location that it would basically be invisible to any thief.
Question is - are these things worthwhile and if so, any suggestions for locations on a 916 Monoposto?
Thanks
Luke
If you're nerdy enough like me you can build your own solution.
I recently used and Arduino + GPS module for tracking lap times (which v1 failed pretty badly. v2 is getting tested on 6/30).
But something like a lowjack is totally possible with a cellular and/or wifi connection. I've never used lowjack but it seems like it would do what you need if you don't want to build one.
On the bike, I would hide it somewhere behind the loom going to the ignition wire/and handle bar controls. I would splice it in on the hot wire before the starter solenoid. Hide it anywhere you see fit. The hot wire being on even with ignition switch/button to off is the key.
In the truck, your choice. Constant power feed to stereo or the brake switch. Both are easy to get to.
Hey all,
After my SP3 got stolen, I am so paranoid about losing my SPS. I have bumped up the security at home and obviously have insurance but the issue is really that if I lost the bike, I couldn't replace it. I have been pondering fitting small 4G GPS tracker but am not sure how effective they are (need line of sight with the sky, own power supply etc.) and also whether I could fit one to the bike in a discreet enough location that it would basically be invisible to any thief.
Thanks
Luke
They are absolutely necessary. I live in a city with a high rate of theft, and when I got a new motorcycle, I started researching how to install GPS tracking equipment. The first recommendation is AMERICALOC, which is compact and has a battery life of several weeks. Second is Spytec, which has a battery life of up to two weeks. They are not just vehicle trackers, they are personal trackers equipped with SOS functions.
