I bought a Ducati 916 1997 and it does not charge the battery. The readings when the bike is Idle are 12.3v after i stated it, and it does not charge while its idle.
The two yellow wires read at around 15.6 on AC setting when they are idle.
When i rev the engine the battery's voltage goes up to around 13.5V. And it does not go higher than that. I raved it up to 11000rpm and the voltage still 13.5.
Also when i rev the engine the two yellow wires read at wound 15.5 AC and it does not go higher even when i redline the engine.
I have been tryn everything the battery is brand new and it gives out 12.7V. Also when i crank the engine the battery's voltage does not go lower than 10V. Bought a new Rectifier and i changed it but still same story.
What do you guys think the problem is?
