Hi everyone ,
I'm Pascal and from Belgium .
I own a Ducati Multistrada Enduro and just bought a ducati 888 strada from '93 and I have some questions for future upgrades.
Is it possible to change the suspension to an ohlins ?
I read a few things but it wasn't sure about some things.
Do I have to change the " triple clamps " ?
It's not necessary for a modern ohlins with radial brakes ( like the 1098 ohlins ) but i think the problem is that i don't find another option
for a more classic ohlins like the ones that were used in the 996/998 .
I read somewhere that someone replaced his original showa from his strada to an ohlins FG43 but i can't find such a fork on the internet either.
All info will be more then welcome.
Thanks in advance .
Grtz ,
Pascal
There were some FG43 that are the correct dimensions so they would be a drop in. I am not sure of current new versions but I did sell a set a couple years ago that was for a early supersport/monster and these are going to work easily.
Another route would be to have some built/modified for you, my current monster Ohlins I built into a set that fit the monster trees instead of modifying the stock trees.
Remember that the 888 SP4 came with Ohlins so there are sets out there. I would go with Ducvet's recommendation and look for a drop in set and maybe update the internals a little, with a rebuild at least, if it's been a while since they were serviced.
Mayor of Simpleton
Hello Pascal.
At the rear, Ohlins shocks are available and even period ones are completely rebuildable. They perform well (though not like a new TTX). You can also use the Ohlins shock for the old M900s, they just have a longer reservoir hose.
As far as the forks go, some of the 851/888 SP models originally used the Ohlins FG9050, but they are tough to find, tough to get some replacement parts for, and most importantly--their performance is poor compared to more modern equipment. The FG43s will be much better, but use a larger axle, so you will either have to use a newer wheel or sleeve the old axle in the fork bottoms. On my ex racebike project I originally went with the adjustable Showas and the 25mm cartridge kit from GP Suspension but then switched to the FG43s for more of a WSB look and to use the Marchesini Mg 5 spokes. The performance of the GP Suspension kit is every bit as good though.
To fit the FG43s, I got some corse replica triples in 53/56mm. I actually still have the takeoff Showas, as well as their adjustable offset billet triples.
Here are some photos of the Showas and Ohlins:
Reactions: paulmm600
Thanks for your reply :)
Hello Pascal.
