AFAM Quick Change Longevity Kit - Early
$374.95
Available in 520 or 525 chain size.
Fits: Ducati 748-998, S2R-S4RS
This kit includes an Afam aluminum sprocket carrier, Afam steel quick change sprocket, Driven light weight steel sprocket and DID's highest rated chain the ZVMX which is available in silver or gold. This kit is designed to be lighter than your OEM set up but is not the lightest kit. Available in 520 or 525 chain size. For a light weight set up see our Afam Lightweight Kit.
This kit utilizes the Afam aluminum carrier and steel quick change sprocket. As the chart below shows this set up is heavier than the Supersprox but will cost less in the long run due to the replacement sprockets for the Afam carrier are less than $60 compared to a complete Supersprox sprocket that is $159.95.
AFAM Quick Change Lightweight Kit - Early
$389.95
Fits: Ducati 748-998, S2R-S4RS.
Everything you need for a light weight sprocket set up.
Available in 520 only. This kit includes an aluminum Afam sprocket carrier, Afam hard anodized aluminum quick change sprocket, Driven lightened front steel sprocket and the light weight DID 520 EVR3 chain. Every piece of this kit was designed for low weight while maintaining strength. If you are looking for a longer lasting set up see our Afam Longevity Kit.
Weight Comparison Chart
Ducati 748 Sprocket Type Weight (lbs) Weight (grams)
Supersprox 520-40 1 lb 13.7 ounces 842
Afam w/ Alum Sprocket 520-40 1 lb 6.7 ounces 648
Afam w/ Steel Sprocket 520-40 2 lbs 7.5 ounces 1120
*All sprockets were weighed at Motowheels.
Outside continental USA, use shipping passwords:
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items. Look for memberships and choose the membership type that fits you the best.
