CF Rear Lower Mudguard: 748-998
Was:$94.00
Sale:$69.00
Lower carbon fiber mudguard mounts under the the swing arm to keep oil and other debris off your rear tire. This under swingarm fender uses the lower chain rub holes to mount. Made by Ducati Performance. Kevlar reinforced on the back side. The perfect complement to the upper rear fender that mounts above the swingarm. List $94
Kevlar reinforced on the backside with pre-drilled holes. Excellent fit and polished finish.
NOTE: Pre-preg Carbon Fiber parts use less resin because it is "cooked" under pressure which results in a stronger and lighter product than typical wet-lay up Carbon Fiber. Pre-preg is the preferred method for racing, and aerospace. It is more expensive to build with this method but it results in a superior product.
* FREE shipping on orders over $100
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items. Look for
memberships and choose the membership type that fits you the best.
